Pattern does not repeat complete feature
sufliky
sufliky
I am designing a grid-like object to mark cuts for a pie. When doing pattern on two features at once the feature is not copied completely. I'm attaching a video here's a commentary:
1. Create a block
2. Chamfer two edges on the block
3. Create pattern for the two features
4. In the middle parts the chamfer is done only on one edge
Red dots symbolize missing chamfer. I would say that the intersaction with exsiting geometry is cutting the edge but only middle parts have the missing chamfer. I have no idea why.
Thank you for all suggestions.
TheCADWhisperer
@sufliky wrote:
I cannot download it because I have a personal license.
What options have you tried?
sufliky
Thanks! I have uploaded the file to the question.
TheCADWhisperer
@sufliky
Attached is one possible solution.
But if this were my design I would use Thin Feature extrusions.
sufliky
Thank you for the reply. Yes I have tried this approach where extrusion is done to a new body. But later on when I will use pattern I have to join the bodies. Unfortunately there is a problem where when a number of elements in pattern is changed I have to rejoin the bodies. I aim to have my model fully parametric.
I checked Thin extrusion but I could not figure out how to use it to get the shape I want.
