Pattern (Circular) question.
kshea9RNL8
kshea9RNL8
An option in pattern is suppress, tried both with and with out and could not see a difference, what does the "Suppress" do?
Ken
jeff_strater
If this option is checked, you can suppress pattern instances using the checkboxes in the graphics area:
If this is turned off, these checkboxes are not available:
Jeff
Jeff Strater
Engineering Director
kshea9RNL8
Thanks Jeff,
I've no clear idea what any of that means but I'll play around with it and perhaps it will make more sense.
Ken
jeff_strater
Oh, sorry, wrote that in too much of a rush.  Pattern suppression allows you to "skip" some instances of the pattern.  Here is a quick video that shows this for a pattern of holes in a plate:
Hope that helps clarify things a bit.
Jeff
Jeff Strater
kshea9RNL8
Oh yes, that cleared it up !
Ken
