So I have a tube, and I would like to make a slot that goes up 1/2 inch, does a 360 around the tube ending 1/2 inch from the other end, and continue the slot straight up. I think I can use a path to cut the slot, but I don't know how to curve the path around the tube. So, How can I curve a line/path around a surface? Attached is the tube.
Thank you for the help.
Solved by jhackney1972. Go to Solution.
For the coil Path, use a one turn Sweep, (with twist) in the surface area.
extend the ends with Extrude.
Might help....
Click the Report and request that the moderator delete the reply.
You did not mention the width of the slot. Here is your tube with a 1/8" slot. If you need further help, please let me know. The only tricky part is the manipulation of the timeline during the process that I used. I am sure that there are others. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Edit: This is in reply to jhackney72. sorry, I'm still learning the forum tools.
Thank you for help.
I believe I can work with this. I'm trying to change some of the parameters, and I need to think about it (the sweep "distance" has no units, which threw me at first).
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask.
John Hackney
Retired
I was thinking about it a little more, and attached is an alternative solution. I had a little trouble thinking about how I would parameterize the other solution. The attached probably isn't 100% correct (getting rid of the spur on the bottom was funky). I also added some fillets to pretty it up.
Again, thank you for the other solution; I learned some new tools and a different way to think about things: some new tools for the toolbox.
You method is great but do note that the slot, being cut varies in its relationship to the tube surface. The one I supplies creates a groove that would be used by a cam follower. Yours creates a perpendicular cut to the tube surface. It depends on what you need and want. If is decorative, then yours works great, if it is functional, mine would be a better choice. Section Cuts of each below.
John Hackney
Retired
