Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Pasten sketch goes on another coordinate
5 REPLIES 5
511 Views, 5 Replies
Hi there. I am trying to copy a sketch but it pastes on a different position than the original one, why does it do it?
Thank you.
5 REPLIES 5
HughesTooling
Can you make a screencast of what you're seeing. Only thought is is the original geometry in another sketch and you're pasting between 2 sketches.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
can you show us this behavior in a screencast?
When I copy elements from sketch and paste them, they appear at same place, what doesn´t make sense.
Then I have to move them to new position.
günther
in reply to: g-andresen
It didn't insert the screencast because it's only accessible with link, it seems. Here it is:
https://autode.sk/2FYT95J
HughesTooling
Well as I thought you are copying from one sketch into another so hard to say without seeing the design. Can you Export your design as an f3d and attach. Don't use the share links, they're a waste of time.
Thanks Mark
Mark Hughes
in reply to: HughesTooling
Unfortunately it seems I don't have that state of the workflow saved. Thanks for the input tho!
Actually I have gone ahead of this making adjustements based with other constrains, so the real problem I have yet is the one in the following topic, which is still related to this one:
https://forums.autodesk.com/t5/fusion-360-design-validate/copying-sketches-lines-disables-surface-wh...
