Passing an arc through a lign
cesar.gironU5U5A
cesar.gironU5U5A
I use 3 points arc definition in a parametric model and i need that point to go over the segment composed by it's two extremities.
Here is an exemple of what i am looking to do with the parameter being 8-12. In that example i had to manualy redraw the arc cause the software doesnt allow the pass over.
Does someone have a solution or maybe a way around  (using conic or spline maybe) ?
Thanks in advance
jeff_strater
Yes, this is correct.  The Fusion sketch constraint/dimension system will not allow that arc to flip like that.  This is just a limitation of the system, so in this case, redrawing the arc is your only option, unfortunately.
Jeff
Jeff Strater
Engineering Director
cesar.gironU5U5A
Well in that case gotta try to find a way around it.
If anyone hasan idea i was thinking working with conical curves which are not subject to this limitation....
Will let you know if i can find a way ^^ (at least approximate the closest i can)
