Sketch Mirror command, Object and Mirror line cannot be selected
sfox2WMDD
sfox2WMDD
Hi
I would like to mirror a sketch in a construction line both made in previous sketches, but I'm not able to select those sketches when in the mirror command.
A simplified version:
Create Sketch, select XY plane
Center Rectangle with center at origo and 2 x dimension => black
Stop Sketch
Vertical Line through origo, center constraint, X for construction line => black
Stop Sketch
Circle C placed somewhere in the left side of the rectangle, 2 x dimension to fully define the circle => black
Stop Sketch
(I want to mirror the circle in the construction line, but I'm not able to select the circle (The Object), and if I click the "Mirror Line" I'm not able to select the construction line either)
What do I do wrong?
Thanks for your help!
Kristian
davebYYPCU
Mirror works with all the / your current articles in the active sketch.
Might help...
sfox2WMDD
As far as I understand your answer, I can only use a construction line as a mirror line when all is created within the same sketch ( Create Sketch - Stop Sketch).
This means that if I, while making another sketch, want to reuse the same construction line as a mirror line, I will have to draw a new construction line on top of the old one.
I like to divide my construction into several sketches as it makes it easier to edit afterwards, but it seems that there are limits to this idea.
Kristian
davebYYPCU
You can Project the Mirror Line into the current sketch, is a copy but not redrawn....
