parting line draft
parting line draft
Message 1 of 25
parting line draft
hi
im doing some of the model mania solid works projects i am currently doing model mania 2004 phase 1
In solid works when creating a draft you can choose a parting line instead of a plane is there a way to achieve this with fussion
this is on the top part of the model
john
Replies (24)
Message 21 of 25
.....at all?
Message 22 of 25
Just realized the functionality is not built in - I use Parting Line draft in Solidworks nearly 100% of the time, and have been trying to convert to Fusion for side work. Will check IdeaStation and upvote if it has already been suggested.
Message 23 of 25
Just an FYI, I didn't see an Idea for parting line draft, so I created one...support it if you'd like to see it added to the draft tool!
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/parting-line-draft/idi-p/7458967
Message 24 of 25
I'm disappointed that Autodesk chose not to include the create parting line command in Autodesk Mechanical. I have been using MDT2009 since, well, 2009. The parting line tool in it kind of sucks, but with some repair work one can create a decent parting line using that tool. I have maintained my subscription to Inventor and Mechanical to have a more contemporary modelling tool and to have that parting tool, but there is so much baggage in that program (for a guy with fairly simple 3-d needs) to take the time to learn it.
Message 25 of 25
rishabh.bisht
Happy to share that Parting Line Draft is now available in Fusion with June 2020 release.
I'd encourage you to give it a try and share your feedback.
Thanks!
Rishabh Bisht
Product Owner
