Parametric modeling
Parametric modeling
Josh3GG88
Message 1 of 8
Parametric modeling
Josh3GG88
If anyone can help me, any help will be appreciated.
I am looking for a function for a parametric template. I have a board that i want to split into 48 inches, but when the remainder gets smaller than 12", i want it to split into equal part. is there anyway possible to do that? I know if I would have an IF...THEN...ELSE option i would be able to.
Replies (7)
Message 2 of 8
stiller.design
there is no option for IF, THEN, ELSE
maybe you can try something the MAX(XX,XX) or the FLOOR, CEILING expression
Message 3 of 8
Warmingup1953
Yes that is what I have seen done for similar "logic" requirements as in this Tutorial...https://www.youtube.com/watch?v=-BPcktQwIIY&ab_channel=LearnEverythingAboutDesign
Disclaimer:...I've never utilised it myself!
Message 4 of 8
stiller.design
really good tutorial channel !!! not easy to find good advanced tutorials on youtube
Message 5 of 8
TrippyLighting
Yep, that is because advanced tutorials often require more than 15 minutes.
Message 6 of 8
Josh3GG88
Yes, i agree that is very good, but it does not quite give me the answer that i am looking for. Would it be possible to find an alternative to this function I will try my best to write:
Length = 100
BoardSplit = 48
Rem = Length % BoardSplit
SplitPoint = Ceil(Length/BoardSplit)
If rem < 12 then
    min(Length/SplitPoint;BoardSplit)
else
    BoardSplit
end if
This function applies to an Offset plane from the end.
It would be very nice if i could find anything that would work for fusion.
Thanks.
Message 7 of 8
KristianLaholm
Here is my suggestion:
To my knowledge there is a bug with modulus (x % y) if the parameters have units, that's why all my parameters are No Units.
Test file attached, solid/surface components are for visual checking the parameters.
Message 8 of 8
Josh3GG88
this works great! Thanks.
