Parameters not working first time
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi I've been using parameters for as long as I have been using Fusion 360, but now they will not work the first time. I type them in, make a drawing, type the desired parameters in, hit enter, and the shape goes to the desired size of the parameter but is not actually using the parameter (i.e. I change the parameter and nothing will happen to the shape), I then have to edit the shape and type the parameter in again and then it will use the parameter. I don't know if this is a setting I've accidentally changed, but it was just working fine.
