Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Parameters and expressions (formulas)
9 REPLIES 9
Message 1 of 10
jkelindberg
14608 Views, 9 Replies
I know the request for parameters have already been raised, but I would like to expand on the topic to include the possibility of using these parameters anywhere instead of any given number. And I would like to be able to use these parameters in expressions for anywhere a number can be entered. This is very handy if you need to make a transformation to/from cylindrical or spherical coordinates. Much the same way as it works in CATIA for example where any numerical input box can be right-clicked and you can select to enter a formula.
Labels (2)
9 REPLIES 9
Message 2 of 10
schneik-adsk
in reply to: jkelindberg
Take a look at the Change Parameters dialog box
http://help.autodesk.com/cloudhelp/ENU/Fusion-Form/files/GUID-76272551-3275-46C4-AE4D-10D58B408C20.h...
Also any time you enter a number you can enter a formula and you can mix units.  Is this what you were looking for?
Kevin Schneider
Message 3 of 10
jkelindberg
Yes! I can hardly believe how I could have missed it! Thanks.
Message 4 of 10
in reply to: schneik-adsk
Hi, I noticed that your link is no longer valid. Is this information still accessible somewhere?
Message 5 of 10
HughesTooling
Here's a link to the help on the change parameter dialog.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 10
matth
in reply to: HughesTooling
How do you accomplish a2 + b2 = c2:
sqrt(a^2 + b^2) = c
I cannot figure out the unit conversions...
MSH | Matt
Message 7 of 10
HughesTooling
in reply to: matth
Does this help. Note you can't use c as a name.
Mark
Mark Hughes
Message 8 of 10
matth
I couldn't get that to work for me! I opted to go with a unitless value instead.
It is working now just have an extra parameter...
MSH | Matt
Message 9 of 10
HughesTooling
in reply to: matth
Another option is to set all the parameters to no units.
Mark
Mark Hughes
Message 10 of 10
404 Page not Found.
Fusion 360 would be a lot easier to learn if there was a written reference guide to follow.
(Edit: Nevermind, I found the link later in the thread, but there doesn't seem to be any way to delete my post)
