Parameters and expressions (formulas)
9 REPLIES 9
Message 1 of 10
jkelindberg
14730 Views, 9 Replies
jkelindberg
I know the request for parameters have already been raised, but I would like to expand on the topic to include the possibility of using these parameters anywhere instead of any given number. And I would like to be able to use these parameters in expressions for anywhere a number can be entered. This is very handy if you need to make a transformation to/from cylindrical or spherical coordinates. Much the same way as it works in CATIA for example where any numerical input box can be right-clicked and you can select to enter a formula.
Labels (2)
9 REPLIES 9
Message 2 of 10
schneik-adsk
in reply to: jkelindberg
schneik-adsk
Take a look at the Change Parameters dialog box
http://help.autodesk.com/cloudhelp/ENU/Fusion-Form/files/GUID-76272551-3275-46C4-AE4D-10D58B408C20.h...
Also any time you enter a number you can enter a formula and you can mix units.  Is this what you were looking for?
Kevin Schneider
Kevin Schneider
Message 3 of 10
jkelindberg
jkelindberg
Yes! I can hardly believe how I could have missed it! Thanks.
Message 4 of 10
in reply to: schneik-adsk
Hi, I noticed that your link is no longer valid. Is this information still accessible somewhere?
Message 5 of 10
HughesTooling
HughesTooling
Here's a link to the help on the change parameter dialog.
Mark
Mark Hughes
Owner, Hughes Tooling
Mark
Mark Hughes
Message 6 of 10
matth
in reply to: HughesTooling
matth
How do you accomplish a2 + b2 = c2:
sqrt(a^2 + b^2) = c
I cannot figure out the unit conversions...
MSH | Matt
sqrt(a^2 + b^2) = c
MSH | Matt
Message 7 of 10
HughesTooling
in reply to: matth
HughesTooling
Does this help. Note you can't use c as a name.
Mark
Mark Hughes
Mark
Mark Hughes
Message 8 of 10
matth
matth
I couldn't get that to work for me! I opted to go with a unitless value instead.
It is working now just have an extra parameter...
MSH | Matt
MSH | Matt
Message 9 of 10
HughesTooling
in reply to: matth
HughesTooling
Another option is to set all the parameters to no units.
Mark
Mark Hughes
Mark
Mark Hughes
Message 10 of 10
404 Page not Found.
Fusion 360 would be a lot easier to learn if there was a written reference guide to follow.
(Edit: Nevermind, I found the link later in the thread, but there doesn't seem to be any way to delete my post)
404 Page not Found.
