Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
On my Mac Book Pro (macOS Sierra 10.12.3 (16D32)), I've run into the problem of resizing the parameter window. The tiny square in the lower right corner that allows window resizing is outside the screen even when running Fusion in full screen an lifting the parameter window to the top.
- Is there a settings file where I can change the parameter window height?
- Is there a keyboard shortcut where I can use arrow keys to alter the size (used such techniques in Windows)?
- Any other available trick?
Suggestion for Autodesk:
- The window size should be possible to change when dragging any corner or frame and/or
- Maximum available window size should be checked on opening the parameter window
