- Mute
- Permalink
- Report
Hello All!
I have attached the f3d file below of which I am about to speak.
It is a confusing file (sorry) but I can't seem to get my prameters to update correctly.
What this is is a wooden box case. There is an interior box. Then there is a variable thickness foam lining and an exterior box, with removable front and rear lids.
My eventual plan is to make a sketch using the parameters defined in the file in order to extrude the wood peices to cut the box. Then, I can change the foam line and case dims to quickly create different sized boxes.
Primitive "RackCase" (dims d1 d2 and d3) are the big "controlling" dims on this project.
Primitive "ExteriorCaseBody" is the outside case.
Primitive "InteriorCaseBody" is the inside case.
Primitives "FrontLid" and "RearLid" are, of course, the front and rear lid.
I want RackCase to define the dimensions of everything. FrontLid depth defines the lid depth.
FoamLine needs to be a variable.
FrontLid and RearLid need to have the height and width of the ExtCase body so they can fit on ExtCase.
However, it doesn't seem like my parameters update correctly when I change them.
See the attached screenshot as well. ExtCaseH has three different values (see d8 vs d22).
What did I do wrong? Should I have my variables in a different order?
Compute All doesn't fix it either.
Any help would be greatly appreciated. Thanks so much!
