Parallel Joint
Parallel Joint
Parallel Joint
I'm trying to creat a parallel joint within my assembly that doesn't restrict a planer offset. I have a piece that flaots in a pin/slot joint vertically and i want to keep that piece parallel to the base plate. I've tried every joint i can, but I keep getting conflicting errors. (see attached pic)
The pin in slot drives the distance, but allows the assy to rotate still, so I just need a Parallel only constraint... any thoughts?
TrippyLighting
That is not per-se a joint but a geometric constraint.
Fusion 360'sjoint system intends to work just a joints would work in the physical world.
At the curent moment there is nothing mechanically in your design that would prevent that part to pivot around the pin/shaft.
Once you've desinged that mechanical constraint you'll likely find that one of the available joints fits the bill perfectly.
