copy & paste measured values
I'm trying to copy & paste a measured value from the measure dialog box. the command says click to copy to clipboard, but when I attempt to paste the value in to my parameters table, I'm not given the option. Earlier this evening, before the update installed, I was able to paste previously copied stuff from my clipboard, but it wasn't the copied value from the meaure dialog box, it was web adresses copied from eariler work.
It would be really cool to measure a value, copy it, then insert it in to the paramters table to ensure accuracy with assembly fit and so on.
Matt
HughesTooling
To copy to the clipboard from the measure dialog you need to double click on the value.
Mark
Mark Hughes
Owner, Hughes Tooling
RajkumarIlanchelian
As Mark mentioned you need to double click to copy the value currently. This is however a bug since the intent is to copy the value with a single click as you would expect. Fix coming.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
N387031
Community Visitor
Community Visitor
having the same problem in 2022
etfrench
If you single click on a value in the any of the dialogs, the value will be put in the clipboard.  The UI (Windows) no longer shows that the copy was done.  Ctrl V will paste it in the Parameters dialog.
If this isn't working for you, make a screencast showing what you're doing.
ETFrench
