Over Constrained Sketch error message when it isn't!
oyaroygoldman
oyaroygoldman
I am getting the Over-constrained Sketch error message when I try to apply a dimension between a new line and an existing one, but there is no constraint applied to the new line except horizontal. What could be causing this?
I am attaching the file here - the line I am trying to define is the horizontal construction line in the top of the sketch. I am trying to apply a dimension between it and the first line below it.
https://a360.co/41YCdXd
TrippyLighting
How would you determine hat this sketch isn't over constrained?
My recommendation would be to break this sketch into several smaller sketches and also avoid mirroring too many sketch objects.
oyaroygoldman
Thanks for the reply.
That is what I ended up doing - I started a new sketch for that upper section, projecting some of the geometry I had already done.
I am pretty new to Fusion and still figuring out when to start a new sketch.
I was thinking the sketch wasn't over constrained because the line I was attempting to dimension wasn't constrained at all, beyond a "horizontal" constraint. I tried re-defining some of the lines I was trying to constrain the new line to, thinking perhaps the dimensions driving them were the issue. I even tried deleting and redrawing them with new dimensional constraints. When I went to redraw them, adding dimensions to them also resulted in an "over constrained sketch" error.
Do you think the sketch mirroring I did is the problem? It does seem a bit messy to mirror mirrors like I did, but the lines I was dealing with weren't constrained to those mirrored sketch elements at all, as far as I could see.
I guess I have the solution now, but I am still curious as to how these kinds of issues arise. Seems like every day a new problem emerges with doing something I swore I did exactly the same the day before. I guess that's learnin' for ya!
Cheers
TheCADWhisperer
(Almost) never ever use sketch mirror. Not necessary.
Mirror Features, Faces, Bodies or Components instead.
Duplicating dimensions is unnecessary work too.
Using Thin Feature Extrude and Mirror of Feature you could dramatically simplify this sketch.
White dots and blue lines should keep you awake at night.
Repeated dimensions like this are a sure sign that you are doing too much work.
And wayyyy too many symmetry (mirror constraints).
How much interest do you have in learning to do this right? (I ask this question because most beginners I ask this question quickly abandoned the discussion.)
Thin Feature and Feature Pattern (Feature Mirror is a type of Feature Pattern) will become your best friends.
TheCADWhisperer
@oyaroygoldman
See Attached for start of best practices...
