Over constraind joint
4 REPLIES 4
david
409 Views, 4 Replies
Sliding joint is over constrained by rigid joint to another component
4 REPLIES 4
TrippyLighting
in reply to: david
Remove one of the joints.
david
in reply to: TrippyLighting
Then the bracket wont move with the part it's attached to.
TrippyLighting
in reply to: david
What bracket ? Would you be able to share your model ?
chrisplyler
in reply to: david
Something is Grounded in the rigid assembly or group that the bracket is attached to. So when you try to make the bracket slide on a third part, the whole thing that should move along with the bracket doesn't move. Figure out what's Grounded and un-Ground it.
