- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am a very wet behind the ears newbie but understand that origins can't be moved. I also understand that they are critical. The last design I did required the importation of several step files, so first, a question:
Do the origins get created at the time of import? If so does the placement affect this origin?
Possible hack:
Generally this hasn't been a problem but I recently had an issue. While pondering, I started to clean up the file and I dragged a component body into another component in such a way that the dragged body seemed to adopt the origin of the parent component.
Is this possible? Is it desirable?
