Origin is not align with grids
majianjia
Message 1 of 16
majianjia
It seems there is a misalignment between grids and origin. How can I fix that?
Replies (15)
Message 2 of 16
jeff_strater
share the design.  It is impossible to tell from just an image.  Is that the global origin, or a component origin.  Is that the Layout Grid, or a sketch grid?
Jeff Strater
Engineering Director
Message 3 of 16
majianjia
It is a global origin. The design is attached.
Message 4 of 16
jhackney1972
Opened your file, and created the exact same view, the grid is aligned as far as I can see.  Refresh your design by either Compute All command or save, close and reopen it.
John Hackney, Retired
Message 5 of 16
jeff_strater
same for me.  The grid looks aligned to the origin OK.  I was looking at the Layout Grid.
Jeff Strater
Message 6 of 16
majianjia
Hi @jeff_strater @jhackney1972 thanks for replys.
Here is my screen record
https://autode.sk/35vLubq
I have to magnify it quite a lot to see the misalignment.
It actually causes lines that cannot snap together so I think the issue exists.
I am able to align the grids to the origin using adapted grids but this is not I want.
UPDATE:
It looks like there are only 2 files out of a few in the same project affacted. So it shouldnt be a globle setting issue or software issue.
Message 7 of 16
g-andresen
I can confirm the statements by @jeff_strater  and @jhackney1972
günther
Message 8 of 16
majianjia
I think it might be related to an auto-update yesterday. Everything was ok before the date.
I am trying to reinstall fusion360
Message 9 of 16
majianjia
uninstall fusion using the official cleaning tools. Deleted all local files and cache.
But it still not help. I think I have to make another project for it.
Have a search around, I found another person has met the same issue.
https://forums.autodesk.com/t5/fusion-360-support/how-to-align-grid-and-origin/td-p/8847363
There is no solution for the post
I toggle the visability of sketches, found that the offset grids are related to some of the sketchs.
https://autode.sk/3q3geKh
Message 10 of 16
jeff_strater
I doubt that any update is related.  This area of Fusion has not changed in years.  Can you share one of the designs that is showing bad behavior?  Your video shows that this is only an issue with adaptive grids.  So, for now, I'd recommend fixed grid.
Jeff Strater
Message 11 of 16
majianjia
Hi @jeff_strater
The attached file is the one associate with the screen record of this
https://knowledge.autodesk.com/community/screencast/7108298c-db1f-4203-a01b-a2fa7799ec66
As long as I show some of the sketches, the origin move.
I do like to use fixed grids so this confused me. Because the adepter grids just fine but fixed grids have offsets.
Message 12 of 16
jeff_strater
very strange.  I am unable to reproduce this mis-alignment:
Jeff Strater
Message 13 of 16
majianjia
That is why I believe all your and other's trials are totally correct.
But the issue still there even I open the uploaded file instead of opening it from my project cloud. It might be related to my local environment.
This is my version and platform.
Message 14 of 16
rushabhthakkar_910
@jeff_strater , I too see that when I open the Model, grid is not Visible. But as soon as I try to create a Sketch, the grid shows up..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 15 of 16
jeff_strater
@rushabhthakkar_910 - there are two grids in Fusion:  There is the "Layout Grid" that appears outside of sketch.  This is available at all times.  There is also the "Sketch Grid", which only shows up when you are in sketch mode.  I believe that this thread is discussing only the Layout Grid.
Jeff Strater
Message 16 of 16
rushabhthakkar_910
Thank You @jeff_strater for this Information... I did not know that.. Got to know a new thing... !!
(Learning Never Stops)..
Thanks and Regards,
Rushabh Thakkar.
