Orient display during sketch to arbitrary line
bdg215
bdg215
During a sketch, is it possible to automatically orient the screen so that is aligned with a particular line?
I'm finding it frustrating to constantly pan around in order to line up my sketch with the geometry that I am most interested in. I would like to be able to make the auto-orient snap to a line or something temporarily while in a sketch.
Or am I just stuck with panning around?
g-andresen
1. Look at
günther
bdg215
Thanks, that does snap to the plane, but it's still rotated.
Is there some way to make it orient the display so that I can choose an arbitrary line as the x,y, or z axis?
I'm doing a lot of small operations on the inside of a sphere which is requiring that I orient things so that they are perpendicular to other points with a compound angle. It would be helpful if I could auto-rotate the display to a particular line when I'm on a sketch plane.
g-andresen
Maybe 3-D sketch mode with its variable gizmo is what you are looking for.
günther
bdg215
Errr. I don't think 3D sketch is the answer. I don't see how that mode would do anything to "snap" the current view to an arbitrary line.
Basically, I don't want to create a 3D sketch, I want to create a 2D sketch that I can extrude. What I'm look for is a convenient way to rotate the display and snap to a line on that rotation.
g-andresen
please show such a process in a screencast.
günther
