Help me to create a wave panel
valentynchikin
Message 1 of 9
valentynchikin
Good Day everyone.
I am new to Fusion 360 and I struggle to reproduce a following pattern in my project.
Any tips would be very appreciated!
Thank you!
Replies (8)
Message 2 of 9
g-andresen
watch this tutorial     by @TrippyLighting
günther
Message 3 of 9
valentynchikin
Thank you very much for your reply!
I have already studied above mentioned tutorial, but I could not implement the same technic in my case. In my example there are wave parts that are incomplete and surface could not be done. So either this technic could not be used or I just lack of skills ((
Message 4 of 9
JHRendon
Hi! Tthis video can help you. Maybe you can download that texture from Mudbox or make it in Mudbox software. There is really easy.
https://www.youtube.com/watch?v=yV8cOjNYnLY
Message 5 of 9
TrippyLighting
That technique can be used. It is a bit more involved, but it is possible.
However, This can also is done with T-Splines.
Let me know if the attached model with what you see in the image above helps.
The techniques @JHRendon linked to can also be very powerful. I'd use Blender as it is free, open-source software.
Message 6 of 9
valentynchikin
@TrippyLighting
Thank you very much! This was really helpful and the issue is now solved!
Message 7 of 9
g-andresen
if you are interested in wave panels, you might also be interested in the development of modulated curves.
However, with this application you can "only" generate toolpaths for such panels, but not 3-D models for further use in applications.
The panels can be created individually in desired sizes for seamless joining.
günther
Message 8 of 9
valentynchikin
To: @g-andresen
Thank you for your answer, I will definitely check this out!
Message 9 of 9
TrippyLighting
@g-andresen That is very cool! Thanks for sharing!
