Orient a shape in a sketch
I'm coming from Rhino3D, Fusion 360 is an amazing CAD software, but I dont understand how to do some basic operations.
Two newbie questions about fusion360 sketches.
1. First question, how to orient a shape on the grid lines :
2. Second question, how to align a shape on another shape :
Thanks for your help.
Jérôme
etfrench
Here's one way to align sketch items:
  1. Use the Dimension tool to get the angle.
  2. Select all of the geometry to move.
  3. Rotate the geometry to the angle found earlier.
Change locations of the sketch items:
  1. Do steps from above.
  2. Use the Move command with Point to Point option.
Other Constraint options on the Sketch Pallet may also be used.
ETFrench
Thank you @Anonymoussharing your problem with the community.
simply use the nodes of sketch and put on the node of other sketches.
and 2nd method is using move command selecting the all sketch together.
Bhavesh Raghwani
