Opening a single model issues
JonSchaeffer
JonSchaeffer
I had just finished a model for a customer who was in imediate need for this, and told them it was done and I could export it for them.
I am now unable to open this one file. AndI keep getting the Fusion 360 error reports.
The last thing I was doing with the model was trying out different rendering skins to create a picture of the finished product. And it crashed and since then it has been unrecoverable.
www.genesisprecisionaz.com
info@genesisprecisionaz.com
kris_berg
Hi @JonSchaeffer ,
I looked at your CER's.  It is not a known issue.  It would be good if you can share the design with us and we can investigate the issue.  You can share it and send me the link (kris.berg@autodesk.com).
For now, I would promote a previously saved version.  To promote a previously saved version see my post at the bottom of the page here http://forums.autodesk.com/t5/general-fusion-360-questions/mac-drawings/td-p/5532170/page/3  Note: while this case was for a drawing, you use the same method to promote a previous version of a design.  Also I would exit the render environment before saving. This is solely based on a suspicion of mine after looking at the CER.  We will know more after looking at your design.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
JonSchaeffer
Thank you,
That worked perfectly.
I believe it was stuck in the render/save mode.
