Use upload in the data panel, the cloud icon. Note you have to be in a project to upload.
Mark
Mark Hughes
Owner, Hughes Tooling
I have the same issue - I am in a Project and select the cloud upload icon and then the f3z file. I select the Project as "Location" there and press okay but then nothing happens. I wait and refresh the project in the Data panel but the new design never shows up there.
Is there a way to see the progress of the upload or if errors happened?
After selecting the fz3 file and clicking Upload you should see a dialog box like this, there's also a progress meter at the bottom of the data panel.
Mark
Mark Hughes
I get unfortunately none of those. The upload window closes immediately after clicking the upload button with no feedback at all.
@Mike.Grau Any ideas on what might be wrong.
Mark
Mark Hughes
I can unzip the f3z and then open the (one and only) f3d that is in it via "New Design from File" but I think this is not how opening a f3z is supposed to work
No you shouldn't need to do that, does the assembly stay linked loading the files one at a time? Not sure who's available from support at the weekends let's try @James.Youmatz.
Mark
Mark Hughes
Can you attach the file here?
@Anonymous wrote:
Here is the file.
The file uploads OK but it only has one design in it. Seems odd that it's an f3z if there are no linked parts, have you modified the file?
Mark
Mark Hughes
OK I guess you downloaded from the dashboard or a download link, for some reason they are giving you an FZ3 file even for a single part design. Looks like a bug.
Mark.
Mark Hughes
Thanks, @HughesTooling. I've seen some cases like this as well. I'll look into it with the data management team. There's nothing wrong with this - you can still upload it and it will just create that single design in your project, but I agree that it seems odd.
Jeff
Thanks @jeff_strater also seems @reiner couldn't upload the file from his data panel just to add to the problem.
Mark
Mark Hughes
Good point. Yes, I'm not sure if those are related or not. The other thing which makes f3z less useful is that you cannot do "New Design From File" with it.
OK, we'll see if we can track this down.
Jeff
I downloaded that f3z from A360 after another person shared it with me.
Would be great if that import could be fixed. If you need more info from me, let me know.
dont know if i may complain since i am using the educational license and i dont have to pay for it...
but this issue is from 2016 and not been resolved...
my fusion is not connecting to the cloud i would love to continue working offline but its seems that there is no way to access the files, or open fusion archives with fusion.
AFAIK You can only open .f3z files when being online with Fusion 360. It’s always been this way and I doubt it’ll change.
f3z files are just zip archives, so you can extract the individual model files with any zip extractor.
@rogercaplan F3Z files are usually generated because they are linked designs, either a 2d drawing or an assembly. If you extract the files manually the links will be broken, so OK if you want the individual files but your assembly will not open.
For a while the cloud exporter would export single files as f3z but I think that's fixed.
Mark
Mark Hughes
