Opacity control in render
yoshimitsuspeed
Advisor Advisor
Message 1 of 9
yoshimitsuspeed
Is opacity control supposed to not work in the rendering environment? It sure would be nice if it did.
For example if you want to render a closeup on a component with a component covering it partially visible without needing to go in and change the material properties.
https://www.facebook.com/groups/1229995573786339/
Replies (8)
Message 2 of 9
TrippyLighting
No, the opacirty control in the model space viewport is really an aid to modeling or for quick visualization.
Fusion 360 uses a physically based rendering approach and if you want transparency you need to select a transparent material e.g.glas, acrylic plastic ets.
Message 3 of 9
yoshimitsuspeed
Don't you think it would be just as useful in the rendering environement though?
Message 4 of 9
TrippyLighting
You can achieve a simlar effect but much better looking IMHO with using  for example the "Glass - Light Color" from the material list.
Drag it to your object and then right-click on thhe materila icon and select duplicate. Then right-click on the duplicate and select edit.
This will allow you to edit the absorption distance. More distance means more transparent and vice versa.
Rename the material to what you like and save to your favorites for re-use in the next project.
BTW, here's another little hint. But small radii on all your visble edges. That will make any rendering look so much better than these unnatural sharp edges.
Message 5 of 9
yoshimitsuspeed
I am also not having luck trying to create a similar efect in rendering. Either the part is too refractive distorting the component below or the component above is not clearly visible and just looks like a shadow.
Message 6 of 9
yoshimitsuspeed
You must have posted right before me. I was playing with various glass and I just tried the one you suggested and it has the same issue it distorts the image behind it but if you use a refractive index of 1 it just looks like a weird shadow. Any other number and it's distorted.
Message 7 of 9
TrippyLighting
In that case, you can change the refractive index closer to 1.
Message 8 of 9
yoshimitsuspeed
Yeah but it looks like crap at 1 and anything other than 1 distorts the view.
Message 9 of 9
ADSKDJW4
Hello yoshimitsuspeed,
I have sent you an email through the support case. I would like to have the data so I can review your situation if that is possible.
Best Regards.
Don
