I have created three components closed phi spring, open phi spring and clamped phi spring.
I am trying to move these different positions of springs into their proper assembly location.
I ground clamped phi spring and can move the open phi spring around until I like the position then I can fix it their using a rigid joint.
Then I want to move the closed spring into its position I can't grab and move this component.
What am I doing wrong?
Solved by g-andresen. Go to Solution.
