One component will not move to make a joint.
1 REPLY 1
jscott6SWZG
65 Views, 1 Reply
I have created three components closed phi spring, open phi  spring and clamped phi spring.
I am trying to move these different positions of springs into their proper assembly location.
I ground clamped phi spring and can move the open phi  spring around until  I like the position then  I can fix it their using a rigid joint.
Then I want to move the closed spring into its position I can't grab and move this component.
What am I doing wrong?
1 REPLY 1
g-andresen
in reply to: jscott6SWZG
ungrounf this component
günther
Technology Administrators
