I am working to create a parametric enclosure with the box and lid in the same file. The lid is made by slightly modifying the projected geometry of the box with a few offsets. All works fine until I change the parameters that control the size of the box. When the parameters are changed, the box and the projected geometry in my lid sketch update fine, but the offsets in the lid sketch do not update to remain concentric with the projections. Does anyone have a way to get this to work?
Box and box sketch:
Box and lid sketches before changing parameters
Box and lid sketches after changing parameters
Showing offset constraints in lid sketch
Solved by etfrench. Go to Solution.
Could you attach the file?
Go to file > export > .f3d, and attach it to your next comment.
That definitely works. I made all my offsets in the sketch and only projected the ones I wanted to create the lid. Thanks!
There was an issue of offset geometry not always updating reported a couple months ago.
Are you using the latest build of Fusion (2.0.19215)? This build has the fix and is available.
I just checked and I was on 2.0.19207. I updated to 2.0.19215 and tried again. No change.
You don't have to project anything. Just use Start/Object or Start/Offset to set where the extrusion starts from.
ETFrench
Thanks for checking. If you reproduce the sketch in the latest build, does the problem remain?
In the mean time, I've asked a sketch engineer to look at the model. Thanks for providing it.
@devin.kieselB9RNV
Thanks for reporting this issue.
This is known issue (FUS-157812) for us, and team is working on the fix, should get released soon once the validations are completed.
Sameer Babar.
Autodesk Fusion Team.
