Offset - edit dimension
mbelusa.mail
mbelusa.mail
Why is the offset dimension of each line and curve automatically created when I go back to the sketch for editing? If I want to change the offset dimension, I have to change each of the multiple automatically added equal offsets. Any idea for a solution?
Thank you.
jhackney1972
I cannot be sure without the model it is hard to tell, please attach it.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
jeff_strater
This looks like multiple offsets were done.  Can you show a video of how you created these offsets?  If the source curves are all connected, they should just show a single offset with one dimension.
Jeff Strater
Engineering Director
