Break in lines on SVG import
monbleau
monbleau
I imported a SVG that has clean lines.  I checked the illustrator file (source) and the SVG file.
When it imports there is a break in a line and I cannot interact with the object.  How can I fix this?
EDIT: Attached file for reference
jhackney1972
I do not have Illustrator so I cannot comment on how to fix it there but you can easily edit the created sketch in Fusion, remove the Fix constraint and repair the error with the sketch tools.  Attach you model and the Forum users can show you how if needed.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
monbleau
I attached the project to the original post.
Thank you.
g-andresen
Such errors occur from time to time with SVG import.
This clearly visible "break" can be easily repaired.
Smaller gaps can be detected with the help of intersecting lines (divide and conquer).
günther
monbleau
Thank you very much.  That worked.
However, I'm probably being dense but, how the heck do I take that imported SVG with the fixes and scale it to fit on the object?
g-andresen
1. unfix
2. scale
3. position
günther
monbleau
Thank you.  I got it all sorted.
I just gotta learn new behaviors. 😁
