Odd sketch behavior during move command
Message 1 of 9
Replies (8)
Message 2 of 9
innovatenate
Autodesk Support
Autodesk Support
Seems like there is some symmetry constraint somwhere.... I can't spot it, but it seems like one is there. Can you share the file on this forum post?
Nathan Chandler
Principal Specialist
Message 3 of 9
jeff_strater
Yeah, that looks like a solver bug to me. Does it behave any different if you put a dimension on it and change the dimension, instead of dragging it? As Nate says, if you can share the design, we can look at it more closely.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 4 of 9
There is a symmetry constraint, is there an easy way to tell what items are constrained? I'm not used to the Fusion method of showing constraints.
Message 5 of 9
Jon.Dean
Take a look at the following screen-shot. I have pointed to the Symmetry symbols.
Jon.
Jon Dean
Message 6 of 9
So there are three symbols for each single constraint?
Message 7 of 9
jeff_strater
I have been able to reproduce this problem.  It's a nice find, Luke.
This model has only side-to-side symmetry:
As long as I select only one side of the symmetry or the other, Move works OK:
However, if I select both sides of the symmetry, as in the screencast, I see the problem:
I will file this bug, and we can start fixing it.
Jeff
Jeff Strater
Message 8 of 9
jeff_strater
filed as bug FUS-16128. Thanks again!
Jeff Strater
Message 9 of 9
Jeff! Nice work! I thought it was functioning as intended and didn't look too much into it. Again nice work.
Luke
