Numbering in balloons
bbhattarai57MPP
Message 1 of 8
bbhattarai57MPP
I have very complex designs and I need to create balloons in hundreds of them, but this fusion doesn't allow manual numbering. This problem is frustrating me and crashing issues are also coming out. I believe advanced designs are not mint for fusion.
Replies (7)
Message 2 of 8
jhackney1972
You can use the Renumber Command to change the Balloons numbers to any order you desire.  If you want special designed numbers, well that is a different story.  Take a look at the video.
John Hackney, Retired
Message 3 of 8
bbhattarai57MPP
I know this but the problem is with the different sections of the components. Like I want to show 2 sections from the component that's not possible because Autodesk will show the same number every sections of that components.
Message 4 of 8
bwalker145
Change the structure from "First Level" to "All Level" on the Parts List if you want the balloon to show the specific component item number, instead of just the upper-level component/assembly number.
If you're trying to isolate sub-assemblies, make sure you "Suppress" the non-relevant assemblies/components in the browser, instead of just hiding; otherwise, the hidden assemblies/parts will show up in your parts list.
You can then delete all of the auto created balloons, and manually add back only the ones you want to show.
Message 5 of 8
bbhattarai57MPP
Still you dont get what I mean, i dont need automatic table I will create it manually. But the point is I want to balloon manually in the different sections of the component.
Message 6 of 8
liang_chen
Thanks for sharing the feedback.
Current, there will be one unique balloon mumber for the same component in Fusion drawing.  It could be a kind of balloon value override to show 2 sections of the same component, showing as the snapshot below
Please correct me if there is any misunderstanding, or share the details of your requirment. We will track it as internal ticket in our backlog. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Message 7 of 8
bbhattarai57MPP
Neither of these answers are helpful for me really. I am talking about very big assembly with multiple sub assemblies and many components and bodies inside the sub-assemblies. Thank you.
Message 8 of 8
aleksei_ovsienko
I think with the latest update they added the option to create custom symbols. Would creating custom baloons for all numbers and using them work as a workaround?
