NPT pipe threads (new hole wizard)
htulrich
Message 1 of 127
htulrich
Looking through the options on a the new hole creation tool I see all types of pipe threads except NPT.  There are Bsp pipe threads but not Npt? am I missing something?
Replies (126)
Message 61 of 127
jkpugh65
Kramer says, "Not bloody likely".
Message 62 of 127
wmhazzard
They are available in the hole command in the taper tapped tool. They are only cosmetic though but the hole size is correct for tapping.
Message 63 of 127
jkpugh65
I need to 3d print them so I need the threads modeled.
Message 64 of 127
Download a part off of McMaster and transplant the threads manually.
Message 65 of 127
jhackney1972
Long ago, someone shared this parametric model of NPT threads so I have attached it again for you.  You can use it to make internal and external threads.
John Hackney, Retired
Message 66 of 127
dvogt
Community Visitor
Community Visitor
I'm looking forward to see the "model" feature for "holes", and not only for "threads".
Until then, my trick around is to import NPT parts from McMaster, and combine them (cut operation) with the target part I want NPT threads in. This allows me to then 3D print NPT threads with a SLA printer.
Message 67 of 127
Can you 'unmark' this as solved? I don't think NPT thread support is solved until the modeled threads (male and female) are available.
Message 68 of 127
brittonholland
I agree with Tom.  The generally agreed work around of using a McMaster part to create a cut which will result in a NPT thread is insufficient as those parts files from McMaster are not always to a spec that would be suitable for design.  I have done it and it works, but only after I had to scale my part a few times to get it right.  This is extra time and wasted 3D prints in my case.
Message 69 of 127
johnwYMVVZ
I also agree.  The McMaster hack is not an engineering level solution, it's a (hopefully) temporary workaround for non-critical systems.  I wouldn't trust something like this for a real-world project, especially in high-pressure system design.
Message 70 of 127
stiller.design
NPT....are we there yet? its 2021 nudge nudge
Message 71 of 127
taylor.fry
What a basic feature to have been lacking since requested in another thread in 2016.  That's 5 years.  I'm sure we could all list marvels that were completed in 5 years compared to a feature that isn't unheard of...  Tapered threads have existed for a while...
Message 72 of 127
jkpugh65
3 different presidents
Message 73 of 127
3 years later is there a fix?
Message 74 of 127
jhackney1972
Am I missing something, NPT threads are available under the Hole dialog.  Are you looking for modeled threads, if so, yes they are not available.
Message 75 of 127
I need external.
Message 76 of 127
etfrench
Use the internal threads to make the external threads.  Because the threads are tapered,  you don't need to change their size, just adjust the position.
ETFrench
Message 77 of 127
randypetrongelli
This is an interesting solution. Saying you use an additional body with internal npt's to cut the original. However really would love to see this feature implemented finally. This has to be the dozen-th time I've needed external npt's. UGH
Message 78 of 127
j.hughes.
If it has been 5+ years since modeled NPT threads were requested, I'm guessing I'm better off just designing my 3D printed parts to be threaded with a tap?
Message 79 of 127
kferro6YF8G
Community Visitor
Community Visitor
Why hasn't anyone from Autodesk given us an update. It seriously shouldn't take four or five years to implement a thread style used in over 400 million homes and businesses.
Message 80 of 127
wmhazzard
Just curious, why do you need to have modeled NPT threads?
