NPS Straight Pipe Threads?
Message 1 of 16
Hello, I am wondering if I am missing something or if straight pipe threads do not exist in the "Hole" feature?
Jeff
Replies (15)
Message 2 of 16
wmhazzard
The BSP pipe threads are straight pipe threads in the hole command but there is no NPS.
Message 3 of 16
@wmhazzardThanks for the quick response! Unfortunately, NPS is standard in our industry and the British Standard has a completely different thread structure in addition to count. I am hoping someone from Autodesk chimes in 😃 as for implementation it seems pretty easy to add NPS to Fusion as the functionality is there it just need the dimensional data added.
Message 4 of 16
jameshorne0503
Hi Jeff,
Looks like you'll have to add your own custom thread: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Custo...
You could copy the BSP thread family and modify accordingly.
Hope this helps!
Message 5 of 16
Thanks @jameshorne0503 This will work out great!
Message 6 of 16
bxliu
Although this is a workaround, it doesn't solve the problem long term as the library path changes with each Fusion360 update and you need to manually move the file each time. I think the dev should take a look.
Message 7 of 16
MRWakefield
The excellent ThreadKeeper add-in takes care of moving all of your custom thread files automatically. I think there might be some conversations at AD regarding the possibility of relocating the thread files to a static location but I've no idea when or if this might happen.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 8 of 16
moore.michaelw
4 Years later and this still has not been added to the Thread Library.
Went to go put in a 1/2 NPS thread on my model and low and behold... Doesn't exist.
Disappointing to say the least.
Message 9 of 16
bxliu
They literally added a bunch of other fancy threads instead… it’s such an easy update to do
Message 10 of 16
tedbradley314
Adding another voice here. It would be great to get NPS added to the options. I use 1/8-27 NPS and 1/4-18 NPS all the time, but they do not appear to be options available in fusion 360.
Message 11 of 16
Ironsharpmachining
Yet another vote for NPS. Why is this not being implemented..?
Message 12 of 16
chrisgarretson
Community Visitor
Community Visitor
I would like to use the 1/2" NPS thread option... Should I go back to SolidWorks?
Message 13 of 16
benN526L
Community Visitor
Community Visitor
The entire lighting industry is based on NPS threading (1/8-27, 1/4-18, 3/8-18) so adding them to the library seems worthwhile.
Message 14 of 16
MRWakefield
You'll find NPSM included in my custom threads collection, which can be found on my Ko-Fi page. As far as I can tell, this is the one you need. NPS covers three designations: NPSM (National Pipe Straight Mechanical), NPSL (Free-Fitting Mechanical Joints), and NPSH (Hose Fittings). I haven't created an NPSL thread file but for completeness I suppose I should do, seeing as I did the NPSM.
Marcus Wakefield
Message 15 of 16
benN526L
Community Visitor
Community Visitor
Thanks Marcus! I just downloaded and will take a look. Happy to tip once I use it!
Thanks again
Message 16 of 16
MRWakefield
Hope it's what you need.
Marcus Wakefield
