not seeing results
not seeing results
not seeing results
I am trying to use F360, but it seems that, while my attempts at adding items work, they don't show up until I change my view setting.  That is, I get no live feedback when trying to place something in the design, or anything else.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
I am little confused as to what might be happening. Do you mind taking a screenshot or a Screencast of the issue so I can get a better peek firsthand? I am assuming you mean when you insert a design into another one, you are not seeing the actual model update?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thanks for replying.  I have found my solution. It turns out that the graphics settings on F360 were set too high for my system.  After adjusting that, everything is doing fine.
Hello Jss1701
For more you can see this post which link is Given below :-
Best Regards
Anil Kumar
(Student Expert)
