I try to make a drawing from an assembly. I select "full assembly", then fusion 360 takes me to the 2D workspace. I creat the first view and in this view some parts are not shown. Does anyone has a solution for this problem?
Solved by cmiller66. Go to Solution.
Hi Dani,
What type of objects are the parts that are not showing up in the drawing? Are they solids or surfaces? Currently we support drawings of solid bodies only, not meshes, tsplines or surfaces. Are you using distributed design/xrefs? We have identified a bug with drawings created with distributed designs either dropping or duplicating some components. A fix for this is due in the next update.
If you can invite me to your project, christopher.miller@autodesk.com, I will take a look.
Chris
Hi Chris
I've invited you to my project. The name of the assemby is "Pendeluhr 1.1" an "Gegensperr mit Hilfsantrieb". Thank you!
Hi Dani,
Thank you. I was able to reproduce the issue (for example in the drawing of Gegensperr the part called Trommel is missing from the drawing). This looks like the bug with distributed design/xrefs and drawings that I mentioned. Good news is I created drawings of your both of your designs using the latest in-house build and the problem is fiixed there. This fix will be available in the next Update which is scheduled for this upcoming weekend. Please check it after the update and let me know how it goes.
Thanks again for reporting this issue, and very cool designs!
Chris
