Not able to extrude imported sketch from a .dxf file
barry_morgan_uae
Observer Observer
barry_morgan_uae
Observer
Observer
Hi Everyone,
I am quite new at Fusion360 so might be obvious. I have imported a complex sketch from a .dxf file but when i try to extrude it I cannot select it. I have zoomed in as much as possible and I cant see any gaps? Since looking arround for a solution I think the white dots mean it is not complete but when i zoom in fully I am not able to see the ends to link?
programming2C78B
If its not blue shaded, it's open somewhere. Add bisecting sketch lines everywhere to see where the gap is.
Please click "Accept Solution" if what I wrote solved your issue!
g-andresen
window select white dots > constraint > coincident
or
share the file
File > export > save as f3d on local drive > attach to post
günther
Drewpan
This is a known problem with Fusion that .dxf files do not import well at times.
Can you export the actual model to the post and we can look at it and try to help you.
If the shape you want to extrude is not blue then it is broken somewhere.
Cheers
Andrew
barry_morgan_uae
Observer
Observer
Thanks for the help: this did the trick:
