Thread form parameter in thread xml
wib002
Message 1 of 20
wib002
I would like to know what <ThreadForm>7</ThreadForm> means in the header of a thread.xml file please?
Many thanks in advance,
Louis
Accepted solutions (3)
Replies (19)
Message 2 of 20
etfrench
What is the actual file name and location?
ETFrench
Message 3 of 20
HughesTooling
This article used to have information on thread types but looks like it's been edited and the useful info removed!
But I found this in an old thread on the forum. Edit After @MRWakefield  post I updated the Whitworth form to 8.
1. go to thread data folder--> [Fusion install path]\Fusion\Server\Fusion\Configuration\ThreadData
2. make a copy of the thread family that you want to customize, for instance: "ACMEScrewThreads.xml" copy to "MyThread.xml"
3. open the "MyThread.xml", change the "<Name>ACME Screw Threads</Name>" to "<Name>My Customize Threads</Name>"(any name is ok, just make sure it is unique)
4. define thread shape for your customize thread: add "<ThreadForm>0</ThreadForm>" under the <ThreadType>,
        0----trapezoid; 1----sharp; 5----square; 8-----whitworth
     if you don't add this, default shape is trapezoid
5. now you can customize anything, including the pitch/diameters...
Please note:
  •  If you create a thread by your customize file, and save the f3d document, and open it on other machine, when other people try edit the thread, he will get an error message "...the current thread family has no suitable type..."
  • If you directly change a standard thread type, and create a thread save to f3d document, when other people open it on their machine, recompue or edit the thread will get back to standard shape.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 20
MRWakefield
I'd like to add to what @HughesTooling said and say that the Whitworth value of 7 doesn't seem to work any more. Instead you have to use a value of 8.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 5 of 20
HughesTooling
@MRWakefield Thanks, I updated my last post so it doesn't cause confusion if referenced in the future.
Mark Hughes
Message 6 of 20
etfrench
Has ThreadForm been deprecated?  It doesn't seem to exist in any current files.
ETFrench
Message 7 of 20
MRWakefield
AFAIK it's always been missing. I seem to remember a discussion somewhere in the forum a while ago regarding this. It appears that for some unknown reason the thread forms of the standard Fusion-supplied thread files are hard-coded into Fusion. I can't imagine the tag being deprecated if they're going to continue to support user-defined threads. If you play around with a thread file and enter a ThreadForm  value of '8' you will notice that a radius is added to the crest and the root of the thread (a-la Whitworth). Similarly if you enter a value of '5' you get a square thread.
Marcus Wakefield
Message 8 of 20
HughesTooling
It seems like it's hard coded into the default XML files. In the past there have been bugs that stop custom XML files creating the correct profile but the default files worked correctly.
Mark
Mark Hughes
Message 9 of 20
MRWakefield
@HughesTooling wrote:
... In the past there have been bugs that stop custom XML files creating the correct profile but the default files worked correctly.
Mark
Yes, I noticed some issues with a BSW/BSF thread file recently. The figures are correct but I get an error if I select 'Modeled' for some sizes (anything under 2" for example). I've attached the file in case you're interested.
Marcus Wakefield
Message 10 of 20
wib002
It was in a custom thread xml file - for ME threads. File start below:
7
ME Screw Threads 32 TPI
in
55
1
0.250
ME 1/4"
ME 1/4"
Message 11 of 20
wib002
Awesome thanks Mark
Message 12 of 20
wib002
First line of a custom thread file (ME - identical form to BSW)
Message 13 of 20
MRWakefield
I've tried to set up a forum thread as a repository for custom thread files so if you wouldn't mind sharing your Model Engineer's thread could you add it to the thread here?
Thanks.
Marcus Wakefield
Message 14 of 20
HughesTooling
There is a thread on the forum fo ME threads. Attached copy of the XML for 32 and 40 TPI. Don't know if it still works, I notice the thread form is 7 so might need changing?
Mark Hughes
Message 15 of 20
MRWakefield
Thanks @HughesTooling I'll change the ThreadForm value and upload it to the other forum thread.
Marcus Wakefield
Message 16 of 20
rrodriguezF5XQ6
Has anyone else noticed Modeled threads now have radii in the thread form?  Can this be changed?
Message 17 of 20
MRWakefield
Which thread standards are you noticing have radiuses? Certain threads such as those based on the Whitworth form and BA threads should have radiuses whereas metric and UN threads for example don't. If you want to have threads without radiuses you'll need to edit the xml thread files accordingly by setting the ThreadForm tag to a value of '0' (Trapezoidal).
Marcus Wakefield
Message 18 of 20
etfrench
ETFrench
Message 19 of 20
rrodriguezF5XQ6
Here is My internal Thread.  When I modeled this a couple of weeks ago the threads look like the picture you provided.
The I opened my drawing I noticed some of the dimensions were dis-associated.  So I looked at the model to find the radii.
Message 20 of 20
etfrench
Which thread?
ETFrench
