Noobie help with a boat shape
2 REPLIES 2
monbleau
151 Views, 2 Replies
Hey all!
I'm trying to create a boat.  Specifically a sailboat.  Basic shape, no mast or anything on top.
I have a vector I drew in illustrator as a top view.  I can extrude it, but the sides are straight down and the bottom is the same size.
How can I taper the sides AND curve them like a boat?
I'm not trying to be hyper realistic, it's for a CNC project.
2 REPLIES 2
etfrench
in reply to: monbleau
Use section drawings and loft between them.  There are quite a few threads here on modeling boats.
ETFrench
TrippyLighting
@monbleau wrote:
I have a vector I drew in illustrator as a top view...
While that can work, as a newbie you should stay miles away from importing anything and start modeling with the tools in Fusion.
If you can post an image of the desired shape and share your design so far, we can provide better feedback.
Technology Administrators
