No Render Download Button
Markclayto
Message 1 of 8
Markclayto
Hi there i have several renders i have done in the cloud i want to download a couple to edit.
I starteed out after the cloud render had finished just opeing up the tile & hitting download.
I am not sure if i am doing anything wrong but the download option is not longer there (see Picture).
My workflow is the same that does not mean i am doing something wrong as it has been working.
Thanks Mark
Replies (7)
Message 2 of 8
masa.minohara
Hi Mark,
Do you also see the same issue with any other designs? Or is the issue specific to a particular design? Could you try restarting Fusion 360 to see if the download button comes back?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 8
Markclayto
Hi there,
I have started Fusion a few times but had the same effect no download buttons on any of the renders in that model.
This morning I have started my PC this morning gone to the renders of the specific model & the button has come back I have put the before & after screen dumps attached
Many Thanks Mark.
Message 4 of 8
masa.minohara
Hi Mark,
Thank you for the update. I've talked to the development team, and they said it looks like the icons were not loaded successfully due to a network issue. Please let us know if you keep seeing the issue.
Masanobu Minohara
Message 5 of 8
forgejax
I also experienced this issue.  In the same session the icons showed up once but then disappeared again, however I was able to use the buttons by clicking the space where they should show up and tooltips also continued working.
Message 6 of 8
This is not a resolved issue.
Message 7 of 8
I keep seeing it - not sure if Mark Clayton does or not.
Message 8 of 8
mad.macs
I went to download a render today, and it gave me a text file. I took a screenshot instead.
