Hi, I'm trying to insert a patch with tangential edge conditions to the existing surfaces. When I select the entire loop for the patch then there is no option to define the edges at all. Please enlighten me as to what I have done wrong.
Iwan
Unable to enlighten you as to what you have done wrong with this little amount of info given. Don't have a model to go by to see what you are referencing.
@hedesignsinfo wrote:
Hi, I'm trying to insert a patch ...
If the boundary is 4-sided, you want to always use a loft, not a patch.
The patch tool should only be used as a last resort.
