No error message when saving a local file fails
- Mute
- Permalink
- Report
I tried to save a local file and Fusion remembered where I put the file last time. Only problem is that I moved that folder into another folder so the location did not exist. I did not think of that at the time and just hit save. It appeared to work (no error but also no indication of saving which I think is normal). Then I couldn't find the file. I went back and tried saving it again thinking I had just forgotten to hit the last "save" button or something. Then I remembered that I moved folders so selected the new folder location and it worked. I should have gotten some sort of notification the save didn't work.
This is under Windows 7
