I'm try to download a file from a share link, I've entered my email address but not received a download link are there any problems with this feature in A360?
This is the file I'm trying to download http://a360.co/1lpbcol
Mark
Mark Hughes
Owner, Hughes Tooling
Solved by brianrepp. Go to Solution.
Hi @HughesTooling,
I currently am experiencing the same issue. I will check into this and see what the issue might be. Thanks for bringing this to our attention!
@HughesTooling - I assume by now you saw my post from earlier today recognizing this issue? http://forums.autodesk.com/t5/design-validate-document/resolved-fusion-360-a360-share-issue/td-p/599...
Hopefully you should be back to normal now.
