No Analysis folder in browser but whole model has Section Analysis
RogerInHawaii
RogerInHawaii
I opened up a project that I've been working on and find that the entre model has a Section Analysis on it. It's only showing half of the model, like when you do a Section Analysis. But there's no Analysis folder in the browser, which is where a Section Analysis would normally be, where I could just delete it.
I MIGHT have done a Section Analysis the last time I worked on this model, but I don't want it now. And there seems to be no way to get rid of it. I even looked through every single component and sub-component on the off chance that it was somehow deep inside the browser hierarchy, but didn't find it. Isn't it always right there at the top of the hierarchy?
How do I get rid of that Section Analysis?
jhackney1972
In this model, have you ever created a model sketch and used Slice Graphics, from the Sketch Palette?  I have seen this retained in the model, from time to time, after leaving the sketch.  Since you view is not showing a full section, I am thinking this may have happened.  If so, you can go back to the sketch and remove the Slice Graphics check mark and I think it should go away.
John Hackney, Retired
RogerInHawaii
Thank you for the response. I SUPPOSE I might have inadvertently done a Slice Graphics, but frankly I don't even know what that is, how it's done, or what I might have clicked on to cause it.
The view is indeed showing the entire model in what looks like a Section Analysis. The solid colored sections are the INSIDE surfaces of those parts.
I decided to go back to a prior saved version of the model, losing just a few edits, and that Section Analysis (or whatever it is) was no longer there.
And in case anyone's wondering, it's a model of Werner Von Braun's Space Ferry.
TheCADWhisperer
@RogerInHawaii wrote:
... inadvertently done a Slice Graphics, but frankly I don't even know what that is, how it's done, or what I might have clicked on to cause it.
You should always Attach your file here for diagnosis.
HughesTooling
You can toggle and check if a sketch slice is active from the browser as well.
Mark Hughes
Owner, Hughes Tooling
