Newbie with simple cap design to 3d print in Cura
shawn_shayNWX5Z
Observer Observer
shawn_shayNWX5Z
Observer
Observer
I create a  simple cap that I wanted to 3d print. I created a sketch of 7mm circle, extruded to 14mm, used the shell to .25mm inside thickness from the bottom and then drafted the face of the bottom by 1.5 degrees to give it a taper. I exported as stl and then opened in Cura 5.9.
Drewpan
I can see from your picture that there is a zero 3D print time. Is that the issue? What is your actual problem? Can you
attach your fusion file so we can have a look?
Cheers
Andrew
shawn_shayNWX5Z
Observer
Observer
I thought I did. See if this works. Yes why is the file showing no print time and the layers only show as 1.
shawn_shayNWX5Z
Observer
Observer
Here you go
laughingcreek
you're wall thickness is .25mm.  that's really thin.  cura is ignoring that part of the model and not slicing it because it's unprintable with your current settings.
Drewpan
As @laughingcreek has suggested, Cura cannot cope with walls that thin. Most 3D printers for non-industrial use
only have a resolution of 0.2mm so 0.25mm is approaching that limit. Unless you have upgraded your actual print
head on the printer it is unlikely you will be able to print with those tollerances. Many print heads are 0.4mm
nozzles default, hence you have to upgrade them. Some Cura settings will allow you to print to 0.2mm but usually
the quality is quite poor.
Cheers
Andrew
