Connecting faces on a 3d plane
a_schreiberAUCQM
Observer Observer
Message 1 of 8
a_schreiberAUCQM
Observer
Observer
How would you approach connecting these faces so that they follow the outer 3D sketch?
Thanks.
Replies (7)
Message 2 of 8
jeff_strater
Boundary Patch might work.  Loft might work.  Share the file, and it will be easier to help.
Jeff Strater
Engineering Director
Message 3 of 8
a_schreiberAUCQM
Observer
Observer
Thank you for the response. Here is the file.
Message 4 of 8
wersy
Message 5 of 8
jeff_strater
@wersy 's version uses loft, here is another approach using Boundary Patch.  Model is attached.
Jeff Strater
Message 6 of 8
a_schreiberAUCQM
Observer
Observer
Thank you very much for both methods. I really appreciate it.
Message 7 of 8
jhackney1972
If both methods given to you solve your question be sure to select the "Accept Solution" icon on both @jeff_strater and @wersy posts.
John Hackney, Retired
Message 8 of 8
johnsonshiue
Hi! Another approach to consider is to create an 180-deg revolved surface of the oval shape. Use Non-Uniform Scale to "flatten" the surface body. Lastly join it to the solid body. Though it may not be 100% precise according to the 2D sketches, the resultant shape will be very smooth.
Many thanks!
Software Test Engineer
