New to Fusion 36
New to Fusion 36
bryantniesha
Message 1 of 51
New to Fusion 36
bryantniesha
Hello everyone, I'm Niesha. I recently enrolled in a cnc manufacturing class that has us using fusion 360 and I'm still learning my way around the software. I'm looking to connect with as many peoples as I can to master the program. I am eager to learn from everyone in hopes to land a job in manufacturing. Since I started my class in June our teacher has given us a bunch of scale drawings and this one, I'm working on now is pretty tough. I have attached pics of the drawings if someone could help me understand how to create the back piece it looks like it bends up but I'm not sure how to get the proper measurements with that piece going up. Do I create a rectangle or draw lines to make that piece? Any help is appreciated. Thank you in Advance.
Replies (50)
Message 2 of 51
TheCADWhisperer
@bryantniesha
That way we can see that you have made an honest effort to model the geometry on your own.
Message 3 of 51
TheCADWhisperer
@bryantniesha
Hint #1
Message 4 of 51
bryantniesha
Hi I managed to create the front side of the piece so far. The backside I
was having so much trouble with.
Message 5 of 51
bryantniesha
Hey thank you for that hint let me go back now to incorporate that angle for the back part
Message 6 of 51
TheCADWhisperer
@bryantniesha
Hint #2
Click on image above to enlarge the view.
Message 7 of 51
TheCADWhisperer
@bryantniesha
Hint #3
Attach your attempt here and I will show you simple method to complete step-by-step.
Message 8 of 51
bryantniesha
hey can i show u on discord what I mean
Message 9 of 51
TheCADWhisperer
@bryantniesha
Are you using student license?
Message 10 of 51
TheCADWhisperer
Am I supposed to magically know what link you are referring to?
Message 11 of 51
bryantniesha
Sorry I think it shows a bit clearer here you know the two fork pieces in the front. I drew my measurements on the side but they didn't connect with the forks.
Message 12 of 51
TheCADWhisperer
@bryantniesha
OK, now we can move forward with this design.
Start over.
In your new file create a sketch on the top plane and sketch a 2-Point Rectangle as shown.
Message 13 of 51
TheCADWhisperer
@bryantniesha
Dimension the Rectangle as shown below...
Message 14 of 51
bryantniesha
This is that part
Message 15 of 51
TheCADWhisperer
@bryantniesha
This next step is critical - always use symmetry about the Origin when practical.
Add a Midpoint Constraint between the Origin and the midpoint of the left vertical line of the Rectangle.
Message 16 of 51
bryantniesha
Im with you
Message 17 of 51
TheCADWhisperer
This is that part
@bryantniesha
Forget your previous attempt for now.
You were sort of on the right track, but we are starting over.
Message 18 of 51
TheCADWhisperer
Im with you
@bryantniesha
Follow my instruction exactly.
The location of the Origin is critical for easy modeling.
Message 19 of 51
bryantniesha
I see what you mean now this is with constraints
Message 20 of 51
TheCADWhisperer
@bryantniesha
Now add a second 2-Point Rectangle as shown below...
Then add a Midpoint Constraints between the two points shown below...
Now add this 12.836 dimension...
