When you insert a screw into your assembly, it is developed, saved to your Fastener Library database and then inserted as a External Link file. After placement, right click on one of your placed fasteners in the Browser and select Open. Once open go to the Browser and under Document Settings at the top, change the Thread Display to Modeled. Save the file and close. When you go back to your assembly all the fasteners that match the size and length, will need to be update and will change thread type.
The best thing is since you edited an External file in your Database is that when you use the same fastener in your assembly or any other, the thread style will be modeled.
Note: Edit in Place will not give you the same options.
John Hackney, Retired
