Needle projection
Needle projection
basmala.qaysson.7935
Observer Observer
Needle projection
Observer
Observer
Hello !
I´m trying to design a cylinder with needles projected from the surface.
is there any suggestion for how to design a needle ( 1 mm in length and a tip opening 0.5 mm in diameter)?
Also, I got stuck on how to extrude the needle from the surface of the cylinder any help?
StefansB
Try revolve function.
Bunga777
I made a lot of needles on the cylinder because I wasn't sure which direction I wanted the needle to go.
Sketch the needle shape and make the needle in Revolve.
The video is here.
https://knowledge.autodesk.com/community/screencast/e5481bb7-cbc6-4aee-867a-82e32501fa61
We have also pasted the data.
Observer
Observer
Thank you so much!
