Split curved faces
Split curved faces
summerson1990
Split curved faces
summerson1990
Hi! Could you please say how can I split these faces in the V direction exactly in the way they appear when IsoCurve analysis is turned on? Look at the .f3d file attached. Thanks!
Bunga777
Perform BRep Face to T-Splines.
At this time, adjust the number of UVs in the same way.
Immediately run T-Splines to BRep to restore it.
At this time, select the location where you want to keep the edge.
Converting in this way produces a Surface divided by UV lines.
I took a video, I hope it helps.
https://knowledge.autodesk.com/community/screencast/9b539156-2cc0-4dfa-9e98-0d885316ba4c
